Datasheet Texas Instruments UCC2889N — Даташит
СерияUCC2889
МодельUCC2889N
Контроллер автономного источника питания 8-PDIP от -40 до 85
Off-line Power Supply Controller datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 20 фев 2003
18 предложений от 18 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - AC/DC преобразователи
Зенер
Россия и страны ТС
UCC2889N
439 ₽
Эиком
UCC2889N
460 ₽
UCC2889N
1 173 ₽
Hi-Tech Circuit Group
UCC2889N
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаUCC2889N
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodFeedforward,Voltage
Duty Cycle(Max)55 %
Frequency(Max)250 kHz
Gate Drive(Typ)0.2 A
Package GroupPDIP
Special FeaturesError Amplifier,Green Mode,Light Load Efficiency,Soft Start
TopologyFlyback
UVLO Thresholds On/Off8.4/6.3 В
Vin(Max)9.3 В
Vin(Min)8.4 В
  • Evaluation Modules & Boards: UCC3889EVM
    UCC3889 Evaluation Module
  • DN-59A UCC3889 Bias Supply Controller EVM Kit - Schematic
    PDF, 144 Кб, Файл опубликован: 5 сен 1999
    This design note presents a schematic and a photograph of the top-side layout for the UCC3889 Off-Line Bias Supply Controller IC Evaluation Kit. This board accepts both conventional "through-hole" or leaded components as well as their surface-mount counterparts. An additional prototyping area allows engineers to further customize these units to address their projects' specific needs. Component lis
  • U-149 Elegantly Simple Off-Line Bias Supply for Very Low Power Applications
    PDF, 328 Кб, Файл опубликован: 5 сен 1999
    The UCC3889 controller is an off-line, low-power, low-voltage, regulated-bias power supply. The unique circuit topology in this device can be visualized as two cascaded flyback converters, each operating in the discontinuous mode, and both driven from a single external power switch. The significant benefit of this approach is voltage conversion ratios of 400V to 12V, with no transformer and low in
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC2889N
