Datasheet Texas Instruments SN74AUC1G14DBVR — Даташит
СерияSN74AUC1G14
МодельSN74AUC1G14DBVR
Инвертор с одним триггером Шмитта 5-SOT-23 от -40 до 85
SN74AUC1G14 Single Schmitt-Trigger Inverter datasheet
PDF, 992 Кб, Версия: P, Файл опубликован: 8 июн 2017
39 предложений от 18 поставщиков
Микросхема Логический чип, TEXAS INSTRUMENTS SN74AUC1G14DBVR Inverter, Schmitt Trigger, 74AUC1G14, 1Input, 9mA, 800mV to 2.7V, SOT-23-5
SN74AUC1G14DBVR
от 28 ₽
SN74AUC1G14DBVR
40 ₽
SN74AUC1G14DBVR
Hi-Tech Circuit Group
SN74AUC1G14DBVR
Pin55
Package TypeDBVDBV
Industry STD TermSOT-23SOT-23
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаU14RU14F
Width (мм)1.61.6
Length (мм)2.92.9
Thickness (мм)1.21.2
Pitch (мм).95.95
Max Height (мм)1.451.45
3-State OutputNo
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeSCHMITT TRIGGER INVERTER
ICC @ Nom Voltage(Max)0.01 мА
LogicInverting
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerYes
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyInverting Buffer/Driver
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)5.8,4,2.3,1.9,1.6 нс
  • Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)
    PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
    Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC1G14DBVR
