Datasheet Texas Instruments UC3856NG4 — Даташит
СерияUC3856
МодельUC3856NG4
Улучшенный ШИМ-контроллер текущего режима 16-PDIP от 0 до 70
Improved Current Mode PWM Controller datasheet
PDF, 3.3 Мб, Версия: A, Файл опубликован: 7 окт 2010
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаUC3856N
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodCurrent
Duty Cycle(Max)50 %
Frequency(Max)1000 kHz
Gate Drive(Typ)1.5 A
Package GroupPDIP
Special FeaturesError Amplifier,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off7.7/7 В
Vin(Max)40 В
Vin(Min)8 В
  • DN-45 UC3846 UC3856 and UCC3806 Push Pull PWM Current Mode Control ICs
    PDF, 27 Кб, Файл опубликован: 5 сен 1999
    The UC3856 is a pin-for-pin-compatible high-performance bipolar version of the industry standard UC3846. It can replace the UC3846 with few circuit modifications and it features increased speed higher gate-drive current and reduced propagation delays. The UCC3806 is a BiCMOS pin-for-pin compatible ultra-low-power version ideal for battery low-power and high-speed applications. The UCC3806
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3856NG4
