Datasheet Texas Instruments OPA3681E/2K5 — Даташит
СерияOPA3681
МодельOPA3681E/2K5
Тройной широкополосный операционный усилитель SpeedPlus™ с токовой обратной связью и отключением 16-SSOP
Pin16
Package TypeDBQ
Industry STD TermSSOP
Width (мм)3.9
Length (мм)4.9
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA368XU
    DEM-OPA368xU: Evaluation Fixture
  • Evaluation Modules & Boards: DEM-OPA368XE
    DEM-OPA368xE: Demonstration Fixture
  • Tuning in Amplifiers
  • The Current-Feedback Op Amp: A High-Speed Building Block
    PDF, 117 Кб, Файл опубликован: 2 окт 2000
    Although current-feedback amplifiers (CFAs) have been in use for quite some time, there is a reluctance to view them in the same light as voltage-feedback amplifiers (VFAs). For instance, the gain-bandwidth curve of VFAs has a parallel in a transimpedance-bandwidth curve for CFAs. This parameter can be used to determine the closed-loop behavior of the CFA in same way that GBW can for the VFA. Not
  • Op Amp Performance Analysis
Серия: OPA3681 (4)
На английском языке: Datasheet Texas Instruments OPA3681E/2K5
