Datasheet Texas Instruments TMX320C82GGP60 — Даташит
СерияTMS320C82
МодельTMX320C82GGP60
TMS320C82 Digital Signal Processor Data Sheet
PDF, 1.4 Мб, Файл опубликован: 1 апр 1998
TMX320C82GGP60
Pin352
Package TypeGGP
Industry STD TermBGA
JEDEC CodeS-PBGA-N
Width (мм)35
Length (мм)35
Thickness (мм).91
Max Height (мм)1.7
RoHSНе совместим
  • Modified Goertzel Algorithm in DTMF Detection Using the TMS320C80 DSP
    PDF, 101 Кб, Файл опубликован: 1 июн 1996
    This document presents a modified Goertzel algorithm for DTMF tone detection on a TMS320C80 ('C80) 32-bit multiprocessor digital signal processor (DSP). The algorithm detects the incoming frequency with an offset range plus or minus 1.5%. For this application, a basic implementation is provided, but additional testing is required to make this detection algorithm complete. The appendix provides the
  • Acoustic Echo Cancellation Algorithms and Implementation on the TMS320C80
    PDF, 223 Кб, Файл опубликован: 1 май 1996
    Acoustic echo cancellation on the TMS320C8x multiprocessor digital signal processor (DSP) offers high performance and flexibility to meet varying user needs. This document describes the implementation of an integrated N-tap digital acoustic echo canceller on the TMS320C8x parallel processor (PP). A brief discussion of a generic echo cancellation algorithm is provided. A 512-tap (64-ms span) echo
  • TMS320C8x System-Level Synopsis (Rev. B)
    PDF, 516 Кб, Версия: B, Файл опубликован: 1 сен 1995
    The TMS320C8x is Texas Instruments? first generation of single-chipmultiprocessor digital signal processor (DSP) devices. Asingle ?C8x contains up to five powerful, fully programmable pro-cessors:a master processor (MP) and up to four parallel proces-sors(PPs). The MP is a 32-bit RISC (reduced instruction setcomputer) processor with an integral, high-performanceIEEE-754 floating-point
  • Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments TMX320C82GGP60
