Datasheet Texas Instruments LMH6643QMMX/NOPB — Даташит
| Серия | LMH6643Q-Q1 |
| Модель | LMH6643QMMX/NOPB |
Усилитель с выходным сигналом Rail-to-Rail, 130 МГц, 75 мА, 8-VSSOP от -40 до 85
LMH6642Q/LMH6643Q Low Power, 130 MHz, 75 mA Rail-to-Rail Output Amplifiers datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 10 сен 2014
Купить LMH6643QMMX/NOPB на РадиоЛоцман.Цены — от 24 до 181 ₽14 предложений от 13 поставщиков IC OPAMP VFB 2 CIRCUIT 8VSSOP. Voltage Feedback Amplifier 2 Circuit Rail-to-Rail 8-VSSOP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer... | |||
| LMH6643QMMX/NOPB Texas Instruments | 45 ₽ | ||
| LMH6643QMMX/NOPB Texas Instruments | 66 ₽ | ||
| LMH6643QMMX/NOPB Texas Instruments | 115 ₽ | ||
| LMH6643QMMX/NOPB Texas Instruments | 181 ₽ | ||
| Pin | 8 |
| Package Type | DGK |
| Industry STD Term | VSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 3500 |
| Carrier | LARGE T&R |
| Маркировка | 643Q |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | .97 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.07 |
| Mechanical Data | Скачать |
| 2nd Harmonic | 80 dBc |
| 3rd Harmonic | 65 dBc |
| @ MHz | 1 |
| Acl, min spec gain | 1 V/V |
| Additional Features | N/A |
| Архитектура | Bipolar,Voltage FB |
| BW @ Acl | 130 МГц |
| CMRR(Min) | 72 дБ |
| CMRR(Typ) | 95 дБ |
| GBW(Typ) | 130 МГц |
| Input Bias Current(Max) | 2600000 pA |
| Iq per channel(Max) | 4 мА |
| Iq per channel(Typ) | 2.7 мА |
| Количество каналов | 2 |
| Offset Drift(Typ) | 5 uV/C |
| Output Current(Typ) | 115 мА |
| Package Group | VSSOP |
| Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
| Rail-to-Rail | In to V-,Out |
| Rating | Automotive |
| Slew Rate(Typ) | 135 V/us |
| Total Supply Voltage(Max) | 10 +5V=5, +/-5V=10 |
| Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
| Vn at 1kHz(Typ) | 17 нВ/rtГц |
| Vn at Flatband(Typ) | 17 нВ/rtГц |
| Vos (Offset Voltage @ 25C)(Max) | 5 мВ |
- AN-1240 Video Transmission Over Twisted Pair Wire (Rev. C)PDF, 102 Кб, Версия: C, Файл опубликован: 1 май 2013
The circuits in Figure 1 and Figure 2 transmit NTSC video signals over twisted pair wire. They weredesigned and tested for transmitting video on inexpensive CAT-3 twisted pair wire. Even when transmittingon 1000 feet of wire, good quality color video was displayed on a monitor with an NTSC input. Both thetransmit and receive circuits use the LMH6643 dual op-amp that has the proper bandwidth - AN-1244 Photo-Diode Current-to-Voltage Converters (Rev. B)PDF, 132 Кб, Версия: B, Файл опубликован: 1 май 2013
Converting the small output current of a photo-diode transducer to a fast responding voltage is oftenchallenging. This application report provides some ways to use high-speed current feedback and voltagefeedback op amps to do the job.
Серия: LMH6643Q-Q1 (2)
- LMH6643QMM/NOPB LMH6643QMMX/NOPB
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
