Datasheet Texas Instruments TCA9546APWR — Даташит
СерияTCA9546A
МодельTCA9546APWR
1,65–5,5 В, 4-канальный переключатель I2C и SMBus с функцией сброса 16-TSSOP от -40 до 85
TCA9546A Low Voltage 4-Channel I2C and SMBus Switch with Reset Function datasheet
PDF, 939 Кб, Версия: A, Файл опубликован: 16 фев 2015
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаPW546A
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Channel Width4
I2C Address1110 xxx
Package GroupTSSOP
Simultaneously Active Channels1 to 4
Special FeaturesReset Input,5V Tolerant I/O
VCC(Max)5.5 В
VCC(Min)1.65 В
fSCLK(Max)0.4 МГц
tpd max1 нс
  • Evaluation Modules & Boards: TCA9548AEVM
    TCA9548AEVM: I2C 1-to-8 Bidirectional Translating Switch Evaluation Module
  • Choosing the Correct I2C Device for New Designs
    PDF, 87 Кб, Файл опубликован: 7 сен 2016
    The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h
  • Maximum Clock Frequency of I2C Bus Using Repeaters
    PDF, 116 Кб, Файл опубликован: 15 май 2015
    TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters
  • I2C Bus Pull-Up Resistor Calculation
    PDF, 157 Кб, Файл опубликован: 13 фев 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TCA9546A (2)
  • Semiconductors > Interface > I2C > I2C Switches and Multiplexers
На английском языке: Datasheet Texas Instruments TCA9546APWR
