Datasheet Texas Instruments TMP275AIDGKR — Даташит
| Серия | TMP275 |
| Модель | TMP275AIDGKR |
В±0.5В°C Temperature Sensor with I2C/SMBus Interface in Industry Std LM75 Form Factor & Pinout 8-VSSOP -40 to 125
TMP275 В±0.5В°C Temperature Sensor With I2C and SMBus Interface in Industry Standard LM75 Form Factor and Pinout datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 20 ноя 2015
Купить TMP275AIDGKR на РадиоЛоцман.Цены — от 27 до 543 ₽54 предложений от 19 поставщиков SENSOR DIGITAL -40C-125C 8VSSOP. Temperature Sensor Digital, Local -40°C ~ 125°C 11 b 8-VSSOP. Temperature Sensors - Analog and Digital Output... | |||
| TMP275AIDGKR Texas Instruments | от 27 ₽ | ||
| TMP275AIDGKR Texas Instruments | 543 ₽ | ||
| TMP275AIDGKR/TMP275AIDGKT Texas Instruments | по запросу | ||
| TMP275AIDGKR Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | DGK |
| Industry STD Term | VSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | T275 |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | .97 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.07 |
| Mechanical Data | Скачать |
| Addresses | 8 |
| Interface | I2C, SMBus, 2-Wire |
| Iq(Typ) | 50 uA |
| Local Sensor Accuracy(Max) | 0.5 +/- C |
| Package Group | VSSOP |
| Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
| Rating | Catalog |
| Special Features | Configurable Resolution,Programmable Alert,Fault Queue,One-Shot Conversion,Shutdown |
| Supply Current(Max) | 85 uA |
| Supply Current(Typ) | 50 uA |
| Supply Voltage(Max) | 5.5 В |
| Supply Voltage(Min) | 2.7 В |
| Temp Resolution(Max) | 12 bits |
- Thermocouple Temperature Measurements Using Isolated Amplifiers (Rev. A)PDF, 145 Кб, Версия: A, Файл опубликован: 11 авг 2017
The most common thermocouple in use today is the Type K. A Type-K thermocouple is inexpensive accurate and works reliably in harsh environments. Type-K thermocouples can measure temperatures ranging from –200°C to +1250°C and have a Seebeck coefficient of S = 41 μV/K at room temperature. - Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor. - Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TMP275 (8)
- Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
