Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM3631YFFR — Даташит
СерияLM3631
МодельLM3631YFFR
Встроенный драйвер подсветки WLED и мощность смещения для ЖК-панелей 24-DSBGA от -40 до 85
LM3631 Complete LCD Backlight and Bias Power datasheet
PDF, 1.5 Мб, Файл опубликован: 21 авг 2014
Pin24
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY3000
МаркировкаLM3631
Thickness (мм).3
Pitch (мм).4
Max Height (мм).625
Количество каналов2
Duty Cycle(Max)94 %
LED16
LED Current Per Channel25 мА
Package GroupDSBGA
Peak Efficiency90 %
Shutdown Current(Typ)1 uA
Special FeaturesAdjustable Switch Frequency,CABC,Enable/Shutdown,I2C Control,OVP,PWM Control,Power Good,Soft Start
Switching Frequency(Max)1100 kHz
TopologyBoost,Current Sink,LDO,Multi-Channel
ТипInductive
Vin(Max)5.0 В
Vin(Min)2.7 В
Vout(Max)30 В
  • Evaluation Modules & Boards: LM3631EVM
    LM3631EVM Complete LCD Backlight and Bias Power Evaluation Module
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
Серия: LM3631 (1)
  • LM3631YFFR
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments LM3631YFFR
