Datasheet Texas Instruments SN74LVTH2952PWLE — Даташит
СерияSN74LVTH2952
МодельSN74LVTH2952PWLE
Приемопередатчики и регистры октальной шины ABT 3,3 В с выходами с 3 состояниями 24-TSSOP от -40 до 85
SN54LVTH2952, SN74LVTH2952 datasheet
PDF, 849 Кб, Версия: F, Файл опубликован: 10 окт 2003
Pin24
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)0.52 | 1ku
Bits(#)8
F @ Nom Voltage(Max)(Mhz)160
ICC @ Nom Voltage(Max)(mA)0.005
Тип входаTTL/CMOS
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)-32/64
Тип выходаLVTTL
Package GroupTSSOP
Package Size: mm2:W x L (PKG)24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP)
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)(V)3.6
VCC(Min)(V)2.7
Voltage(Nom)(V)3.3
tpd @ Nom Voltage(Max)(ns)4.6
RoHSНе совместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Registered Transceiver
На английском языке: Datasheet Texas Instruments SN74LVTH2952PWLE
