Datasheet Texas Instruments SN74LVC14AQDREP — Даташит
СерияSN74LVC14A-EP
МодельSN74LVC14AQDREP
Усовершенствованный инвертор с шестигранным триггером Шмитта 14-SOIC от -40 до 125
SN74LVC14A-EP datasheet
PDF, 558 Кб, Версия: C, Файл опубликован: 23 май 2006
Pin14
Package TypeD
Package QTY2500
МаркировкаLVC14AE
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Bits6
Тип входаCMOS,TTL
Тип выходаLVTTL
RatingHiRel Enhanced Product
Schmitt TriggerYes
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)2 В
Voltage(Nom)2.5,3.3 В
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
На английском языке: Datasheet Texas Instruments SN74LVC14AQDREP
