Datasheet Texas Instruments BQ24650RVAR — Даташит
| Серия | BQ24650 |
| Модель | BQ24650RVAR |
High Efficiency Synchronous Switch-Mode Charger Controller – Solar Battery Charger 16-VQFN -40 to 85
bq24650 Synchronous Switch-Mode Battery Charge Controller for Solar Power With Maximum Power Point Tracking datasheet
PDF, 3.0 Мб, Версия: A, Файл опубликован: 28 апр 2016
Купить BQ24650RVAR на РадиоЛоцман.Цены — от 67 до 930 ₽52 предложений от 22 поставщиков Микросхема Чип управления батареи, Battery Charge Management High Efficiency Synchronous Switch-Mode Charger Controller Solar Battery Charger Battery Charge Controller Li-Ion/Li-Pol 10000mA... | |||
| BQ24650RVAR Texas Instruments | 146 ₽ | ||
| BQ24650RVAR Texas Instruments | от 212 ₽ | ||
| BQ24650RVAR Texas Instruments | от 213 ₽ | ||
| BQ24650RVAR Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | RVA |
| Industry STD Term | VQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | PAS |
| Width (мм) | 3.5 |
| Length (мм) | 3.5 |
| Thickness (мм) | .9 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| Absolute Vin (safety rating)(Max)( | 33 В |
| Battery Charge Voltage(Max) | 26 В |
| Battery Charge Voltage(Min) | 2.1 В |
| Cell Chemistry | Lead Acid,Li-Ion/Li-Polymer,LiFePO4 |
| Charge Current(Max) | 10 A |
| Control Interface | Standalone (RC-Settable) |
| Control Topology | Switch-Mode Buck |
| Number of Series Cells | 1,2,3,4,5,6 |
| Operating Vin(Max) | 28 В |
| Operating Vin(Min) | 5 В |
| Package Group | VQFN |
| Package Size: mm2:W x L | 16VQFN: 12 mm2: 3.5 x 3.5(VQFN) PKG |
| Special Features | Programmable MPPT Setting,Solar Input,Standard BAT Temp Monitoring,Vin DPM (OK for Solar Power Source) |
| USB Feature | N/A |
- Evaluation Modules & Boards: BQ24650EVM-639
BQ24650 Evaluation Module Synchronous, Switch-Mode, Battery Charge Controller for Solar Power
- Reducing Precharge Phase Region for bq24650PDF, 278 Кб, Файл опубликован: 30 авг 2011
The bq24650 is a battery charger operates in three phases: precharge phase, fast-charge current regulation, and fast-charge voltage regulation. In many applications, a long precharge region is not required when using bq24650 as a charger. Thus, the following application note describes a method of reducing the precharge region for this charger. In this method, a circuit is designed to force the vol - Using the bq24650 to Charge a LiFePO4 batteryPDF, 144 Кб, Файл опубликован: 24 авг 2010
This application report gives an example of using the bq24650 charge management device to provide a high-efficiency, switching-mode charging solution for the LiFePO4 battery. - A Discrete Narrow Voltage DC/DC Charger Solution for Multicell BatteriesPDF, 123 Кб, Файл опубликован: 12 дек 2011
Solar charging applications typically require an input voltage regulation due to large variations in solar celllighting condition. Combining an NVDC (narrow voltage dc/dc) battery charging architectures with solar cell charging can extend battery life and run times by maintaining a very narrow voltage range for the system power. This application report shows how to do a NVDC charger solution wit - Maximum Power Point Tracking With the bq24650 Charger. (Rev. A)PDF, 474 Кб, Версия: A, Файл опубликован: 15 авг 2011
This application report describes a solution to track the maximum power point of a solar panel using a negative temperature coefficient (NTC) thermistor with the bq24650. The basic functionality of a solar panel is described. The use of a spreadsheet tool to aid in the setup process is described as well. - Preventing bq24650 Leakage Current When Using Shaded Solar PanelsPDF, 2.3 Мб, Файл опубликован: 19 сен 2016
- Using the bq24650 to Charge a Sealed, Lead-Acid Battery (Rev. A)PDF, 157 Кб, Версия: A, Файл опубликован: 4 окт 2011
This application report shows how to modify the bq24650 to charge a sealed, lead-acid battery from a solar panel. The circuit uses constant current (CC) charging to reach the bulk battery voltage and then switches to constant voltage (CV) charging until the termination current is reached. The modifications necessary to change the regulated voltage, recharge voltage and regulated current are discus - bq246xx Device ComparisonPDF, 37 Кб, Файл опубликован: 8 окт 2010
This application report presents an overview of the differences among the bq24600, bq24610, bq24616, bq24617, bq24620, bq24630, bq24640, and bq24650 battery charge devices. This document can assist design engineers with selecting the most suitable IC for their respective applications. - A boost-topology battery charger powered from a solar panelPDF, 185 Кб, Файл опубликован: 16 сен 2011
- Bq241x0/3/4/5/8/9, bq24170/1/2, bq24133, bq24610/6 and bq24630/40/50 ComparisonPDF, 59 Кб, Файл опубликован: 24 авг 2011
This application report provides a comparison among bq241x0/3/4/5/8/9, bq24170/1/2, bq24133, and bq246xx . The document presents the main differences and describes the main features of each part. It assists designers in selecting the most suitable charger for their application. - Solar charging solution provides narrow-voltage DC/DC system bus for multicellPDF, 129 Кб, Файл опубликован: 9 ноя 2011
- A solar-powered buck/boost battery chargerPDF, 334 Кб, Файл опубликован: 26 апр 2012
- 2Q 2012 Issue Analog Applications JournalPDF, 2.4 Мб, Файл опубликован: 26 апр 2012
- Журнал РїРѕ применению аналоговых компонентов 3Q 2011PDF, 3.9 Мб, Файл опубликован: 1 сен 2011
- 3Q 2011 Issue Analog Applications JournalPDF, 1.4 Мб, Файл опубликован: 16 сен 2011
- 4Q 2011 Issue Analog Applications JournalPDF, 943 Кб, Файл опубликован: 9 ноя 2011
Серия: BQ24650 (2)
- BQ24650RVAR BQ24650RVAT
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
