Datasheet Texas Instruments 74CB3T1G125DCKRG4 — Даташит
СерияSN74CB3T1G125
Модель74CB3T1G125DCKRG4
Низковольтный переключатель шины с одним полевым транзистором 2,5 В/3,3 В и толерантным устройством сдвига уровня 5 В 5-SC70 от -40 до 85
SN74CB3T1G125 datasheet
PDF, 845 Кб, Версия: A, Файл опубликован: 29 мар 2006
Pin555
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаWMRWMFWM5
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
3-State OutputYes
Bits1
F @ Nom Voltage(Max)90 Mhz
Gate TypeBUS SWITCH
ICC @ Nom Voltage(Max)0.02 мА
LogicTrue
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesVoltage translation,Ioff,5V tolerant I/O,bidirectional,low capacitance and on-resistance
Sub-FamilyDigital Switch/Mux/Demux
Technology FamilyCB3T
VCC(Max)3.6 В
VCC(Min)2.3 В
Voltage(Nom)2.5,3.3 В
tpd @ Nom Voltage(Max)0.15,0.25 нс
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • CBT-C, CB3T, and CB3Q Signal-Switch Families
    PDF, 584 Кб, Файл опубликован: 4 фев 2003
    Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments 74CB3T1G125DCKRG4
