Datasheet Texas Instruments SN65HVD37D — Даташит
| Серия | SN65HVD37 |
| Модель | SN65HVD37D |
Маломощный полнодуплексный драйвер/приемник RS-485, 3,3 В, 14-SOIC от -40 до 85
Low-Power 3.3V-Supply Full-Duplex RS-485 Driver/Receiver datasheet
PDF, 386 Кб, Версия: A, Файл опубликован: 29 ноя 2011
Купить SN65HVD37D на РадиоЛоцман.Цены — от 48 до 425 ₽40 предложений от 16 поставщиков Чип интерфейса, TEXAS INSTRUMENTS SN65HVD37D RS485 Transceiver IC, Full Duplex, 1 Differential Driver, 3V to 3.6V, SOIC-14 | |||
| SN65HVD37D Texas Instruments | от 48 ₽ | ||
| SN65HVD37D Texas Instruments | 159 ₽ | ||
| SN65HVD37D Texas Instruments | 212 ₽ | ||
| SN65HVD37D Texas Instruments | 269 ₽ | ||
| Pin | 14 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 50 |
| Carrier | TUBE |
| Маркировка | HVD37 |
| Width (мм) | 3.91 |
| Length (мм) | 8.65 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Common Mode Range | -7 to 12 |
| Duplex | Full |
| Fail Safe | Idle,Open,Short |
| Fault Protection | -13 to 13 В |
| HBM ESD | 15 kV |
| ICC(Max) | 0.8 мА |
| IEC 61000-4-2 Contact | N/A +/- kV |
| Isolated | No |
| No. of RX | 1 |
| No. of TX | 1 |
| Number of Nodes | 256 |
| Package Group | SOIC |
| Rating | Catalog |
| Signaling Rate(Max) | 20 Mbps |
| Supply Voltage(s)(Nom) | 3.3 В |
- Evaluation Modules & Boards: SN65HVD22EVM
SN65HVD22EVM Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: RS485-FL-DPLX-EVM
RS485-FL-DPLX-EVM: RS-485 Full-Duplex Evaluation Module
- Comparison of Differential-Mode Noise Immunity of RS-485 Recvrs W/3.3-V SupplyPDF, 1.0 Мб, Файл опубликован: 29 ноя 2011
RS-485 is a widely used standard for industrial communication due to its simplicity and suitability for use in high-noise environments on long cables. Inherent in the standard are balanced signal drivers and receivers, which use differential signaling to reject common-mode noise. Receiver hysteresis is commonly used to ensure glitch-free reception even when differential noise is present. This appl
Серия: SN65HVD37 (2)
- SN65HVD37D SN65HVD37DR
- Semiconductors > Interface > RS-485/RS-422
