Datasheet Texas Instruments TAS5711PHPR — Даташит
СерияTAS5711
МодельTAS5711PHPR
Стереоусилитель звука I2S мощностью 20 Вт с эквалайзером динамика, DRC и поддержкой 2.1 48-HTQFP от 0 до 85
TAS5711 20-W Digital Audio-Power Amplifier With EQ, DRC, and 2.1 Mode datasheet
PDF, 2.4 Мб, Версия: A, Файл опубликован: 26 авг 2010
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаTAS5711
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Analog Supply (V)3 Max
Audio Input TypeDigital
Closed/Open LoopOpen
Control InterfaceSoftware
Рабочий диапазон температурот 0 до 85 C
Package GroupHTQFP
Package Size: mm2:W x L48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG
Power Stage Supply(Max)26 В
Power Stage Supply(Min)8 В
Power to Bridge Tied Load(Max)21 W
Power to Parallel Bridge Tied Load(Max)42.8 W
Sampling Rate(Max)48 kHz
Sampling Rate(Min)8 kHz
Speaker Channels3 Max
Supported Bridge Tied Load(Min)6 Ohms
  • Evaluation Modules & Boards: TAS5711PHPEVM
    TAS5711PHP Evaluation Module
  • TAS57xx Dynamic Range Control
    PDF, 324 Кб, Файл опубликован: 18 июн 2010
    This application report provides background information, general equations, and instructions for proper use of the Texas Instruments TAS57xx series Dynamic Range Control (DRC). Topics include I2C configuration, single-band and dual-band DRC, coefficient computation, device offerings, and user interface configuration.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5711 (2)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Digital I2S Input Class-D
На английском языке: Datasheet Texas Instruments TAS5711PHPR
