Datasheet Texas Instruments 74ACT11002D — Даташит
Серия74ACT11002
Модель74ACT11002D
Четверные 2-входовые логические элементы положительного ИЛИ-НЕ 16-SOIC от -40 до 85
Quadruple 2-Input Positive-NOR Gates 16-SOIC -40 to 85
74ACT11002D
Pin16
Package TypeD
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: 74ACT11002 (3)
  • Semiconductors > Logic > Gate > NOR Gate
На английском языке: Datasheet Texas Instruments 74ACT11002D
