Datasheet Texas Instruments TS5A23159RSER — Даташит
СерияTS5A23159
МодельTS5A23159RSER
1-Ом, 5 В/3,3 В, 2-канальный переключатель SPDT 10-UQFN от -40 до 85
TS5A23159 1-О© 2-Channel SPDT Analog Switch 5-V / 3.3-V 2-Channel 2:1 Multiplexer / Demultiplexer datasheet
PDF, 1.1 Мб, Версия: H, Файл опубликован: 26 фев 2015
АЦП азиатских производителей
Pin10101010
Package TypeRSERSERSERSE
Industry STD TermUQFNUQFNUQFNUQFN
JEDEC CodeR-PQFP-NR-PQFP-NR-PQFP-NR-PQFP-N
Package QTY3000300030003000
CarrierLARGE T&RLARGE T&RLARGE T&RLARGE T&R
МаркировкаJEOJERJE7JEV
Width (мм)2222
Length (мм)1.51.51.51.5
Thickness (мм).55.55.55.55
Pitch (мм).5.5.5.5
Max Height (мм).6.6.6.6
Additional FeaturesPowered off protection,Break-before-make
Полоса частот105 МГц
Bandwidth(Max)100 МГц
Configuration2:1 SPDT
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)200 мА
Input/Output OFF-state Capacitance(Typ)18 пФ
Input/Output ON-state Capacitance(Typ)54.5 пФ
Количество каналов2
OFF-state leakage current(Max)0.1 мкА
ON-state leakage current(Max)0.1 мкА
Package GroupUQFN
Package Size: mm2:W x L10UQFN: 3 mm2: 2 x 1.5(UQFN) PKG
Ron(Max)3.5 Ohms
Ron(Typ)0.7 Ohms
Supply Current(Max)0.5 uA
Supply Current(Typ)0.01 uA
Supply Range5.5 Max
VIH(Min)1.5 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)1.65 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
На английском языке: Datasheet Texas Instruments TS5A23159RSER
