Datasheet ТI ADS8317IBDRBR — Даташит
СерияADS8317
МодельADS8317IBDRBR
Datasheet Texas Instruments ADS8317IBDRBR
16-битный, псевдобиполярный, полностью дифференциальный вход, последовательный выход 250kSPS, микросхема АЦП от 2,7 В до 5,5 В 8-SON от -40 до 85
16-Bit, High-Speed, 2.7V to 5.5V microPower Sampling Analog-to-Digital Converter datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 1 окт 2009
  • Interfacing the MSOP8EVM to TMS470 Processors
    PDF, 68 Кб, Файл опубликован: 15 мар 2006
    This application report presents a method for interfacing the modular MSOP8EVM, an evaluation module (EVM) for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters to the TMS470 series microcontrollers. The hardware used for this example includes the TMS470 Kickstart Development Kit evaluation kit featuring the 60-MHz TMS470R1B1M and the HPA-MCU Interface Board. The soft
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS8317IBDRBR
Политика конфиденциальности
