Datasheet Texas Instruments DAC703CH-BI — Даташит
Серия | DAC703 |
Модель | DAC703CH-BI |
Монолитные 16-битные цифро-аналоговые преобразователи 24-CDIP SB
Datasheet
Pin | 24 |
Package Type | JD |
Industry STD Term | CDIP SB |
JEDEC Code | R-CDIP-T |
Width (мм) | 7.37 |
Length (мм) | 27.94 |
Thickness (мм) | 3.5 |
Pitch (мм) | 2.54 |
Max Height (мм) | 4.45 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- Superposition: The Hidden DAC Linearity ErrorPDF, 106 Кб, Файл опубликован: 2 окт 2000
A digital-to analog converter (DAC) translates digital signals to analog signals. For example, a 12-bit DAC takes a 12-bit binary number, called an input code, and converts it into one of 4,096 analog output voltages or currents. When the contribution to the output voltage or current of each individual bit is independent of any other, it means that the device exhibits no superposition error or tha
Серия: DAC703 (11)
- Semiconductors > Data Converters > Digital to Analog Converter > Precision DAC (=<10MSPS)
DAC703CHBI, DAC703CH BI
