Datasheet Texas Instruments LMC6482AI MDA — Даташит
СерияLMC6482-MIL
МодельLMC6482AI MDA
Операционный усилитель CMOS с двойным входом и выходом Rail-to-Rail 0-DIESALE от -40 до 85
LMC6482-MIL CMOS Dual Rail-to-Rail Input and Output Operational Amplifier datasheet
PDF, 2.2 Мб, Файл опубликован: 22 июн 2017
Package TypeY
Package QTY324
  • AN-1237 RSDSв„ў Flat Panel Display Design Guidelines Part 2 (Rev. A)
    PDF, 194 Кб, Версия: A, Файл опубликован: 6 май 2013
    This application report presents part 2 of the flat panel display design guidelines.
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • AN-1234 RSDSв„ў Flat Panel Display Design Guidelines Part 1 (Rev. A)
    PDF, 245 Кб, Версия: A, Файл опубликован: 6 май 2013
    This application report outlines the total system solution that Texas Instruments provides for flat panel displays (FPDs). The described design uses an reduced swing differential signaling (RSDS) interface technology for reduced power, reduced board size, reduced component count, and reduced EMI. This document is currently applicable to XGA and SXGA notebook and monitor applications.
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
Серия: LMC6482-MIL (1)
  • LMC6482AI MDA
На английском языке: Datasheet Texas Instruments LMC6482AI MDA
