Datasheet Texas Instruments TLV2362IDRG4 — Даташит
СерияTLV2362
МодельTLV2362IDRG4
Двойной высокопроизводительный низковольтный операционный усилитель 8-SOIC от -40 до 85
High-Performance Low-Voltage Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 27 июн 2007
Package TypeD
Package QTY2500
Маркировка2362I
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)85 дБ
CMRR(Typ)60 дБ
GBW(Typ)7 МГц
Input Bias Current(Max)150000 pA
Iq per channel(Max)2.5 мА
Iq per channel(Typ)1.75 мА
Количество каналов2
Output Current(Typ)1.2 мА
Rail-to-RailNo
Slew Rate(Typ)3 V/us
Total Supply Voltage(Max)5 +5V=5, +/-5V=10
Total Supply Voltage(Min)2 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)6 мВ
  • Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)
    PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
    This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
  • Conditioning a Switch-mode Power Supply Current Signal Using TI Op Amps
    PDF, 61 Кб, Файл опубликован: 23 мар 2000
    The switch-mode power supply primary current is often sensed using a power resistor. Using an op amp to amplify the current-sense signal can reduce cost and improve noise performance and efficiency. This report reviews the advantages of using an op amp circuit and analyzes the design criteria needed to choose the proper op amp.
На английском языке: Datasheet Texas Instruments TLV2362IDRG4
