Datasheet Texas Instruments OPA454AIDDAR — Даташит
Серия | OPA454 |
Модель | OPA454AIDDAR |
Высоковольтные (100 В) сильноточные (50 мА) операционные усилители, G=1, стабильный 8-SO PowerPAD от -55 до 125
OPA454 High-Voltage (100-V), High-Current (50-mA) Operational Amplifiers, G = 1 Stable datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 31 мар 2016
Pin | 8 |
Package Type | DDA |
Industry STD Term | HSOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | OPA454 |
Width (мм) | 3.9 |
Length (мм) | 4.89 |
Thickness (мм) | 1.48 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.7 |
Mechanical Data | Скачать |
Additional Features | Shutdown |
Архитектура | FET |
CMRR(Min) | 100 дБ |
CMRR(Typ) | 146 дБ |
GBW(Typ) | 2.5 МГц |
Input Bias Current(Max) | 100 pA |
Iq per channel(Max) | 4 мА |
Iq per channel(Typ) | 3.2 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 1.6 uV/C |
Output Current(Typ) | 120 мА |
Package Group | SO PowerPAD |
Package Size: mm2:W x L | 8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ) | 13 V/us |
Total Supply Voltage(Max) | 100 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 10 +5V=5, +/-5V=10 |
Vos (Offset Voltage @ 25C)(Max) | 4 мВ |
- Power Amplifier Stress and Power Handling LimitationsPDF, 55 Кб, Файл опубликован: 27 сен 2000
To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
Серия: OPA454 (4)
- OPA454AIDDA OPA454AIDDAG4 OPA454AIDDAR OPA454AIDDARG4
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
