Datasheet Texas Instruments TPS5210PWP — Даташит
СерияTPS5210
МодельTPS5210PWP
Синхронный понижающий контроллер для процессоров Pentium® 28-HTSSOP от 0 до 0
Programmable Synchronous-Buck Regulator Controller datasheet
PDF, 889 Кб, Версия: A, Файл опубликован: 11 май 1999
IC REG CTRLR BUCK 28HTSSOP. Buck Regulator Positive Output Step-Down DC-DC Controller IC 28-HTSSOP. PMIC - Voltage Regulators - DC DC...
TPS5210PWP
85 ₽
TPS5210PWP
763 ₽
TPS5210PWP
TPS5210PWP
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY50
МаркировкаTPS5210
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementTPS549A20RVER
Replacement CodeF
  • DC-to-DC Converter Parallel Operation Using Droop Compensation of TPS5210
    PDF, 39 Кб, Файл опубликован: 23 июн 1999
  • DC-to-DC Converter Derives 1.2V from 12V
    PDF, 36 Кб, Файл опубликован: 24 фев 1999
    The TPS5210 can generate a regulated 1.2-V output from a 12-V input. The application circuit is identical to the Application shown in the TPS5210 data sheet (SLVS171, Figure 18), except for the modified droop circuit shown in Figure 1. To operate the circuit, voltage reference (V REF ) should be set to 2.2 V using the voltage identification code (VID). Since the droop voltage at pin 2 causes the o
  • Extended Output Voltage Adjustment Using the TPS5210
    PDF, 36 Кб, Файл опубликован: 10 дек 1998
    This application brief discusses how the TPS5210 programmable synchronous buck regulator controller can generate a 1-V output from a 12-V input. The scheme described can also be applied to any output voltage ranging between 0 and 3.5 V.
  • Designing Fast Response Synchronous Buck Regulators Using the TPS5210
    PDF, 479 Кб, Файл опубликован: 10 мар 1999
    This application report describes the operation and performance of a 12-V to 2-V 20-A synchronous buck regulator evaluation design using the TPS5210 Programmable Synchronous Buck Regulator Controller. Experimental data shows tight static and dynamic regulation (?55 mV), fast transient response (within 1 micosecond), high efficiency (up to 90%), and stable operation with good noise immunity. The TP
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TPS5210 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments TPS5210PWP
