Datasheet Texas Instruments UCC25230DRMT — Даташит
СерияUCC25230
МодельUCC25230DRMT
Входной сигнал от 12 В до 105 В, выходной ток 0,2 А, импульсный преобразователь 8-VSON от -40 до 125 В.
12-V to 100-V Input, 0.2-A Output Switching Converter datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 13 апр 2012
Package TypeDRM
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
Маркировка25230
Width (мм)4
Length (мм)4
Thickness (мм).9
Pitch (мм).8
Max Height (мм)1
Iout0.2 A
Package GroupVSON
Package Size: mm2:W x L8VSON: 16 mm2: 4 x 4(VSON) PKG
Soft StartFixed
Special FeaturesIntegrated Switches
Switching Frequency(Max)380 kHz
Switching Frequency(Min)324 kHz
TopologyBuck
ТипFlybuck
Vin(Max)105 В
Vin(Min)8.46 В
Vout(Max)90 В
Vout(Min)3.3 В
  • Evaluation Modules & Boards: UCC25230EVM-754
    Evaluation Module for UCC25230 DC/DC Switching Converter
  • Evaluation Modules & Boards: UCC25230EVM-662
    UCC25230 12V to 105V Input, 0.2A Output Switching Converter Evaluation Module
  • Evaluation Modules & Boards: UCD3138HSFBEVM-029
    UCD3138 Hard Switching Full Bridge Converter Evaluation Module
  • UCC25230 Bias Power-Supply Design Review
    PDF, 197 Кб, Файл опубликован: 23 фев 2012
    This application report reviews the design steps used in the evaluation module (EVM) UCC25230EVM-754. The EVM helps evaluate the UCC25230 pulse-width modulation (PWM) controller in a forwardflyback, or Flybuckв„ў, dc-dc converter topology for a 48-V telecom bias supply. The EVM is a dual-output converter with 1500-VDC isolation between the two outputs. Each output is typically rated as 12 V and 65 m
Серия: UCC25230 (2)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Isolated DC/DC Converter
На английском языке: Datasheet Texas Instruments UCC25230DRMT
