Datasheet Texas Instruments UCC39412PWTR — Даташит
СерияUCC39412
МодельUCC39412PWTR
Синхронный повышающий преобразователь малой мощности 8-TSSOP от 0 до 70
Low Power Synchronous Boost Converter datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 20 июл 2005
Преобразователь DC/DC, Step-Up Regulator Low Power Synchronous Boost Converter Conv DC-DC 1.1V to 3.2V Step Up Single-Out 3.3V 0.06A 0.2W 8Pin...
UCC39412PWTR
185 ₽
UCC39412PWTR
185 ₽
UCC39412PWTR
213 ₽
Hi-Tech Circuit Group
UCC39412PWTR
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка39412
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Duty Cycle(Max)100 %
Iq(Typ)0.048 мА
Package GroupTSSOP
Regulated Outputs1
Switch Current Limit(Min)0.385 A
Switch Current Limit(Typ)0.55 A
Switching Frequency(Max)500 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)3.8 В
Vin(Min)1 В
Vout(Max)3.3 В
Vout(Min)3.3 В
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: UCC39412 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments UCC39412PWTR
