Datasheet Texas Instruments OPA1013DN8G4 — Даташит
СерияOPA1013
МодельOPA1013DN8G4
Прецизионный двойной операционный усилитель с однополярным питанием 8-PDIP 0–70
Precision, Single-Supply Dual Operational Amplifier datasheet
PDF, 147 Кб, Файл опубликован: 27 сен 2000
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаOPA1013D
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)97 дБ
CMRR(Typ)104 дБ
GBW(Typ)0.5 МГц
Input Bias Current(Max)30000 pA
Iq per channel(Max)0.55 мА
Iq per channel(Typ)0.34 мА
Количество каналов2
Offset Drift(Typ)0.4 uV/C
Output Current(Typ)30 мА
Package GroupPDIP
Rail-to-RailIn to V-,Out
Slew Rate(Typ)0.35 V/us
Total Supply Voltage(Min)4 +5V=5, +/-5V=10
Vn at 1kHz(Typ)25 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.3 мВ
  • Single-Supply, Low-Power Measurements Of Bridge Networks
    PDF, 26 Кб, Файл опубликован: 27 сен 2000
    Bridge sensor measurements often need to be made in systems operating on a single 5V power supply. An OPA1013 dual op amp along with a REF200 current source, makes an excellent bridge measurement system which features low power single-supply 5V operation and immunity to power supply variations. One OPA1013 dual op amp is used as a two-op-amp instrumentation amplifier. A second OPA1013 is used with
  • Diode-Based Temperature Measurement
    PDF, 44 Кб, Файл опубликован: 27 сен 2000
    Diodes are frequently used as temperature sensors in a wide variety of moderate-precision temperature measurement applications. The relatively high temperature coefficient of about -2mV/В°C is fairly linear. To make a temperature measurement system with a diode requires excitation, offsetting, and amplification. The circuitry can be quite simple. This Bulletin contains a collection of circuits
  • Implementation and Applications of Current Sources and Current Receivers
    PDF, 427 Кб, Файл опубликован: 27 сен 2000
    This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA1013 (4)
На английском языке: Datasheet Texas Instruments OPA1013DN8G4
