Datasheet Texas Instruments THS4011IDGNRG4 — Даташит
СерияTHS4011
МодельTHS4011IDGNRG4
Усилитель с обратной связью по напряжению, 290 МГц с низкими искажениями 8-MSOP-PowerPAD от -40 до 85
290-MHz Low-Distortion High-Speed Amplifiers datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 12 апр 2010
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
МаркировкаACJ
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
2nd Harmonic80 dBc
3rd Harmonic80 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl290 МГц
CMRR(Min)82 дБ
CMRR(Typ)110 дБ
GBW(Typ)290 МГц
Input Bias Current(Max)6000000 pA
Iq per channel(Max)9.5 мА
Iq per channel(Typ)7.8 мА
Количество каналов1
Offset Drift(Typ)15 uV/C
Output Current(Typ)110 мА
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)310 V/us
Total Supply Voltage(Max)30 +5V=5, +/-5V=10
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)7.5 нВ/rtГц
Vn at Flatband(Typ)7.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)6 мВ
  • Evaluation Modules & Boards: THS4011EVM
    THS4011 High Speed Amplifier Evaluation Module
  • Nulling Input Offset Voltage of Operational Amplifiers
    PDF, 94 Кб, Файл опубликован: 2 авг 2000
    The input offset voltage of operational amplifiers (op-amps) arises from unavoidable mismatches in the differential input stage of the op-amp circuit caused by mismatched transistor pairs, collector currents, current-gain betas(B), collector or emitter resistors, etc. This application report describes the effects of mismatched components on the input offset voltage, and proposes using an external
  • Using a Decompensated Operational Amplifier for Improved Performance
    PDF, 161 Кб, Файл опубликован: 30 мар 2001
    Decompensated operational amplifiers have improved noise, slew rate, harmonic distortion, etc., but required external compensation for stable operation. This report shows how to compensate such an amplifier and achieve the performance enchancement it provides in a unity-gain configuration.The THS4011 and THS4021 operational amplifiers are used to illustrate the superior performance mentioned a
  • Using a decompensated op amp for improved performance
    PDF, 352 Кб, Файл опубликован: 11 мар 2005
На английском языке: Datasheet Texas Instruments THS4011IDGNRG4
