Datasheet Texas Instruments ADS7831U — Даташит
СерияADS7831
МодельADS7831U
12-битный КМОП аналого-цифровой преобразователь с частотой дискретизации 600 кГц 28-SOIC
Datasheet
TSP
АЦП азиатских производителей
Pin28
Package TypeDW
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
RoHSНе совместим
  • What Designers Should Know About Data Converter Drift
    PDF, 95 Кб, Файл опубликован: 2 окт 2000
    Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its operating-temperature extremes, perhaps only to 9 or even 8 bits. But for lack of more precise knowledge, many play it safe (and expensive) and overspecify.
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Interleaving Analog-to-Digital Converters
    PDF, 64 Кб, Файл опубликован: 2 окт 2000
    It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration several possible sources of error.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7831 (2)
  • Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
На английском языке: Datasheet Texas Instruments ADS7831U
