Datasheet Texas Instruments OPA2381AIDGKTG4 — Даташит
| Серия | OPA2381 |
| Модель | OPA2381AIDGKTG4 |
Прецизионный маломощный трансимпедансный усилитель 8-VSSOP от -40 до 125
OPA381, OPA2381: Precision, Low Power, 18MHz Transimpedance Amplifier datasheet
PDF, 992 Кб, Версия: B, Файл опубликован: 18 ноя 2004
Купить OPA2381AIDGKTG4 на РадиоЛоцман.Цены — от 98 до 174 ₽9 предложений от 9 поставщиков Микросхема Буферный усилитель, Precision, Low Power, Transimpedance Amplifier 8-VSSOP -40℃ to 125℃ | |||
| OPA2381AIDGKTG4 Texas Instruments | 141 ₽ | ||
| OPA2381AIDGKTG4 Texas Instruments | 174 ₽ | ||
| OPA2381AIDGKTG4 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | DGK |
| Industry STD Term | VSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Маркировка | A62 |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | .97 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.07 |
| Mechanical Data | Скачать |
| Additional Features | Tiny Package |
| Архитектура | FET |
| CMRR(Min) | 95 дБ |
| CMRR(Typ) | 110 дБ |
| GBW(Typ) | 18 МГц |
| Input Bias Current(Max) | 50 pA |
| Iq per channel(Max) | 1 мА |
| Iq per channel(Typ) | 0.8 мА |
| Количество каналов | 2 |
| Offset Drift(Typ) | 0.03 uV/C |
| Output Current(Typ) | 10 мА |
| Package Group | VSSOP |
| Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
| Rail-to-Rail | Out |
| Rating | Catalog |
| Slew Rate(Typ) | 12 V/us |
| Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
| Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
| Vn at 1kHz(Typ) | 114 нВ/rtГц |
| Vos (Offset Voltage @ 25C)(Max) | 0.025 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2381 (6)
- OPA2381AIDGKR OPA2381AIDGKRG4 OPA2381AIDGKT OPA2381AIDGKTG4 OPA2381AIDRBT OPA2381AIDRBTG4
