Datasheet ТI ADS1202IPWRG4 — Даташит
СерияADS1202
МодельADS1202IPWRG4
Datasheet Texas Instruments ADS1202IPWRG4
Дельта-сигма-модулятор с токовым шунтом, CLK 10 МГц, вход +/-250 мВ, разрешение 16 бит, 8-TSSOP от -40 до 85
ADS1202: Motor Control Current Shunt, 1-Bit, 10MHz, 2nd-Order D-S Modulator datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 12 июл 2004
  • Choosing an Optocoupler for the ADS1202 Operating in Mode 1
    PDF, 116 Кб, Файл опубликован: 12 фев 2003
    The ADS1202 is a precision, 80-dB dynamic range, delta-sigma modulator operating from a single +5-V supply. The differential inputs are ideal for direct connections to transducers or low-level signals. With the appropriate digital filter and modulator rate, the device can be used to achieve 15-bit analog-to-digital conversion with no missing codes. This application report describes how to choose a
  • Interfacing the ADS1202 Modltr With a Pulse Transformer in Galvanically Isolated
    PDF, 292 Кб, Файл опубликован: 2 июн 2003
    The ADS1202 is a precision, 80-dB dynamic range, delta-sigma modulator operating from a single +5-V supply. The differential inputs are ideal for direct connections to transducers or low-level signals. With the appropriate digital filter and modulator rate, this device can be used to achieve 15-bit analog-to-digital conversion with no missing codes. This application report describes how to interfa
  • Clock Divider Circuit for the ADS1202 in Mode 3 Operation
    PDF, 151 Кб, Файл опубликован: 15 сен 2003
    The ADS1202 is a precision, 80dB dynamic range, delta-sigma (О”ОЈ) modulator operating from a single +5V supply. The differential inputs are ideal for direct connections to transducers or low-level signals. With the appropriate digital filter and modulator rate, the device can be used to achieve 15-bit analog-to-digital conversion with no missing codes. This application note describes ho
  • Using the ADS1202 Reference Design
    PDF, 448 Кб, Файл опубликован: 19 ноя 2003
    This application report describes the characteristics, operation, and use of the ADS1202 reference design. It includes two isolated ADS1202 circuits for a variety of applications and a SincВі filter implemented in a XilinxВ® XC2S150 field-programmable gate array. Optional optocouplers provide addtional isolation. A complete circuit description and schematic diagram are included.
  • Combining ADS1202 with FPGA Digital Filter for Current Msrmnt in Motor Cntrl App
    PDF, 375 Кб, Файл опубликован: 28 апр 2003
    The ADS1202 is a precision, 80dB dynamic range, delta-sigma(О”ОЈ) modulator operating from a single +5V supply. The differential inputs are ideal for direct connections to transducers or low-level signals, such as shunt resistors. With the appropriate digital filter and modulator rate, the device can be used to achieve 15-bit analog-to-digital (A/D) conversion with no missing codes. This
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1202 (4)
На английском языке: Datasheet Texas Instruments ADS1202IPWRG4
Политика конфиденциальности
