Datasheet Texas Instruments OPA2107APG4 — Даташит
СерияOPA2107
МодельOPA2107APG4
Прецизионный операционный усилитель Dual Difet® 8-PDIP
Precision Dual Difet® Operational Amplifier datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 4 июн 2003
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаOPA2107AP
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)80 дБ
CMRR(Typ)94 дБ
GBW(Typ)4.5 МГц
Input Bias Current(Max)10 pA
Iq per channel(Max)4.5 мА
Iq per channel(Typ)4.5 мА
Количество каналов2
Offset Drift(Typ)3 uV/C
Рабочий диапазон температурот -25 до 85 C
Output Current(Typ)40 мА
Package GroupPDIP
Rail-to-RailNo
Slew Rate(Typ)18 V/us
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at 1kHz(Typ)9 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)1 мВ
  • Comparison of Noise Performance of FET Transimpedence Amp/Switched Integrator
    PDF, 66 Кб, Файл опубликован: 27 сен 2000
    Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2107APG4
