Datasheet Texas Instruments UCC28951QPWRQ1 — Даташит
СерияUCC28951-Q1
МодельUCC28951QPWRQ1
Полномостовой контроллер со сдвигом фазы для широкого диапазона входного напряжения 24-TSSOP от -40 до 125 В.
UCC28951-Q1 Phase-Shifted Full-Bridge Controller for Wide Input-Voltage Range Applications datasheet
PDF, 2.7 Мб, Файл опубликован: 13 апр 2016
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаUCC28951Q
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Control MethodCurrent,Peak Current Mode,Voltage
Duty Cycle(Max)97 %
Frequency(Max)1000 kHz
Frequency(Min)50 kHz
Gate Drive(Typ)0.2 A
Package GroupTSSOP
RatingAutomotive
Special FeaturesAdjustable Switching Frequency,Current Limiting,Enable/Shutdown,Error Amplifier,Green Mode,Programmable Slope Compensation,Soft Start,Soft Switching,Synchronization Pin,Thermal Shutdown
TopologyPhase-Shifted Full-Bridge
UVLO Thresholds On/Off7.3/6.7 В
Vin(Max)20 В
Vin(Min)8 В
  • Gate Driver Design Considerations
    PDF, 229 Кб, Файл опубликован: 10 окт 2016
    The UCC28950/UCC28951-Q1 phase-shifted full-bridge controllers offer several features to improve power conversion efficiency at light loads. In particular, as the load current drops below the DCM threshold the duty cycle applied to the transformer reduces and eventually the device enters a burst mode. This application note describes how a user can design their gate driver circuits to operate corre
Серия: UCC28951-Q1 (1)
  • UCC28951QPWRQ1
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC28951QPWRQ1
