Datasheet Texas Instruments 5962-89905012A — Даташит
Серия | UC1823 |
Модель | 5962-89905012A |
Высокоскоростной ШИМ-контроллер 20-LCCC от -55 до 125
High Speed PWM Controller datasheet
PDF, 2.9 Мб, Версия: B, Файл опубликован: 5 авг 2009
![]() 8 предложений от 7 поставщиков Микросхема Контроллер PWM, Current Mode PWM Controller 1.5A 1000kHz 20Pin CLLCC Tube | |||
5962-89905012A Texas Instruments | 3 805 ₽ | ||
5962-89905012A Texas Instruments | от 16 994 ₽ | ||
5962-89905012A Texas Instruments | по запросу | ||
5962-89905012A | по запросу |
Pin | 20 |
Package Type | FK |
Industry STD Term | LCCC |
JEDEC Code | S-CQCC-N |
Package QTY | 1 |
Carrier | TUBE |
Width (мм) | 8.89 |
Length (мм) | 8.89 |
Thickness (мм) | 1.83 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.03 |
Mechanical Data | Скачать |
Control Method | Current |
Duty Cycle(Max) | 80 % |
Основные особенности | Error Amplifier,Soft Start,Synchronization Pin,Multi-topology |
Frequency(Max) | 1000 kHz |
Frequency(Min) | 0.1 kHz |
Package Group | LCCC |
Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
Rating | Military |
Topology | Boost,Buck,Flyback,Forward |
UVLO Thresholds On/Off | 9.2/8.4 В |
Vin(Max) | 30 В |
Vin(Min) | 8.4 В |
RoHS | See ti.com |
- U-131 Simple Switchmode Lead-Acid Battery ChargerPDF, 206 Кб, Файл опубликован: 5 сен 1999
Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
Серия: UC1823 (6)
- 5962-89905012A 5962-8990501EA UC1823J UC1823J883B UC1823L UC1823L883B
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
596289905012A, 5962 89905012A
