Datasheet Texas Instruments CD54HCT30F3A — Даташит
| Серия | CD54HCT30 |
| Модель | CD54HCT30F3A |
Высокоскоростная логика КМОП, 8 входов, вентиль NAND, 14 CDIP, от -55 до 125
CD54/74HC30, CD54/74HCT30 datasheet
PDF, 821 Кб, Версия: D, Файл опубликован: 21 авг 2003
Купить CD54HCT30F3A на РадиоЛоцман.Цены — от 663 до 3 250 ₽14 предложений от 14 поставщиков Микросхема Логический чип, NAND Gate 1Element 8IN CMOS 14Pin CDIP Tube | |||
| CD54HCT30F3A Texas Instruments | 663 ₽ | ||
| CD54HCT30F3A(5962-897460 Texas Instruments | по запросу | ||
| CD54HCT30F/3A Texas Instruments | по запросу | ||
| Pin | 14 | 14 |
| Package Type | J | J |
| Industry STD Term | CDIP | CDIP |
| JEDEC Code | R-GDIP-T | R-GDIP-T |
| Package QTY | 1 | 1 |
| Carrier | TUBE | TUBE |
| Маркировка | 5962-8974601CA | CD54HCT30F3A |
| Width (мм) | 6.67 | 6.67 |
| Length (мм) | 19.56 | 19.56 |
| Thickness (мм) | 4.57 | 4.57 |
| Pitch (мм) | 2.54 | 2.54 |
| Max Height (мм) | 5.08 | 5.08 |
| Bits | 1 |
| F @ Nom Voltage(Max) | 25 Mhz |
| ICC @ Nom Voltage(Max) | 0.02 мА |
| Тип входа | TTL |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | 4/-4 мА |
| Тип выхода | CMOS |
| Package Group | CDIP |
| Package Size: mm2:W x L | See datasheet (CDIP) PKG |
| Rating | Military |
| Schmitt Trigger | No |
| Technology Family | HCT |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| tpd @ Nom Voltage(Max) | 35 нс |
| RoHS | See ti.com |
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HCT30 (2)
- 5962-8974601CA CD54HCT30F3A
- Semiconductors > Space & High Reliability > Logic Products > Gate Products
