Datasheet Texas Instruments INA101CM1 — Даташит
СерияINA101
МодельINA101CM1
Инструментальный усилитель очень высокой точности 10-к-100
Very High Accuracy Instrumentation Amplifier datasheet
PDF, 262 Кб, Файл опубликован: 27 сен 2000
Измерительные усилители Very High Accuracy Instrumentation Amp
INA101CM1
TradeElectronics
INA101CM1
INA101CM1
Pin10
Package TypeLME
Industry STD TermTO-CAN
JEDEC CodeO-MBCY-W
Width (мм)8.96
Length (мм)8.96
Thickness (мм)4.4
Pitch (мм)2.92
Max Height (мм)5.72
Approx. Price (US$)7.95 | 1ku
Bandwidth at Min Gain(Typ)(MHz)0.3
CMRR(Min)(dB)106
Gain Error (+/-)(Max)(%)0.2
Gain Non-Linearity (+/-)(Max)(%)0.002
Gain(Max)(V/V)1000
Gain(Min)(V/V)1
Input Bias Current (+/-)(Max)(nA)30
Input Offset (+/-)(Max)(uV)50
Input Offset Drift (+/-)(Max)(uV/C)2
Iq(Typ)(mA)6.7
Noise at 0.1 Hz - 10 Hz(Typ)(uVpp)0.8
Noise at 1kHz(Typ)(nV/rt(Hz))13
Number of Channels(#)1
Operating Temperature Range(C)-55 to 125
Package GroupPDIP
SOIC
Package Size: mm2:W x L (PKG)See datasheet (CDIP SB)
See datasheet (PDIP)
Vs(Max)(V)40
Vs(Min)(V)10
RoHSНе совместим
  • AC Coupling Instrumentation and Difference Amplifiers
    PDF, 38 Кб, Файл опубликован: 27 сен 2000
    The need to glean AC signals from DC in the presence of common-mode noise frequently occurs in signal conditioning applications. AC coupling to an instrumentation amplifier (IA) or difference amplifier can be used to accurately extract the AC signal while rejecting DC and common-mode noise.
  • Semiconductors > Amplifiers > Instrumentation Amplifiers
На английском языке: Datasheet Texas Instruments INA101CM1
