Datasheet Texas Instruments UCC28251RGPT — Даташит
СерияUCC28251
МодельUCC28251RGPT
Усовершенствованный ШИМ-контроллер с операцией предварительного смещения 20-QFN от -40 до 125
UCC28251 Advanced PWM Controller With Prebias Operation datasheet
PDF, 1.8 Мб, Версия: E, Файл опубликован: 29 дек 2014
Pin20
Package TypeRGP
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Маркировка28251
Width (мм)4
Length (мм)4
Thickness (мм).93
Pitch (мм).5
Max Height (мм)1
Control MethodCurrent,Feedforward,Voltage
Duty Cycle(Max)100 %
Frequency(Max)1000 kHz
Frequency(Min)40 kHz
Gate Drive(Typ)0.2 A
Package GroupQFN
Special FeaturesLeading Edge Blanking,Multi-topology,Programmable Slope Compensation,Soft Start,Synchronization Pin
TopologyForward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off4.3/4.1 В
Vin(Max)20 В
Vin(Min)4.3 В
  • Evaluation Modules & Boards: UCC28250EVM-564
    Evaluation Module for UCC28250 Adv.PWM Controller w/ Pre-biased Load Op. on Secondary Side Control
  • Evaluation Modules & Boards: UCC28250EVM-501
    Evaluation Module for UCC28250 Advanced PWM Controller on Primary Side Control
  • Differences Between the UCC28251 and UCC28250 and Evaluation of the UCC28251 in (Rev. A)
    PDF, 36 Кб, Версия: A, Файл опубликован: 15 фев 2013
    The UCC28251 is a functional variant of the UCC28250 PWM Controller. While the same basic functionality of the UCC28250 is largely maintained, the UCC28251 is designed to operate at a lower frequency (minimum of 27 kHz when programmed by RT pin) allowing operation in 400-V input DC-to-DC converters in off-line AC-to-DC power supplies, where frequency-dependent high-voltage switching lossesare an
  • Fast input-voltage transient response with digitally-controlled isolated DC/DC
    PDF, 293 Кб, Файл опубликован: 24 июл 2015
  • Analog Applications Journal 3Q 2015
    PDF, 7.1 Мб, Файл опубликован: 24 июл 2015
Серия: UCC28251 (4)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC28251RGPT
