Datasheet Texas Instruments UCC39421PW — Даташит
СерияUCC39421
МодельUCC39421PW
Высокочастотный многорежимный синхронный контроллер 16-TSSOP от 0 до 70
Multimode High Frequency PWM Controller datasheet
PDF, 896 Кб, Версия: C, Файл опубликован: 4 фев 2005
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY90
Маркировка39421
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
  • UCC39421 3.3V SEPIC Evaluation Board (Rev. B)
    PDF, 77 Кб, Версия: B, Файл опубликован: 8 авг 2001
    The UCC39421 SEPIC demo board implements a complete 330-kHz, 3.3-V SEPIC converter. The user needs only to supply an input voltage and a load. A list of materials giving the component part numbers and case sizes, the schematic, and a typical efficiency curve are provided.
  • 30 Watt Boost Converter Using the UCC39421 Multimode Synchronous PWM Controller
    PDF, 341 Кб, Файл опубликован: 15 фев 2000
    This design note discusses the use of the demonstration kit to evaluate the performance of the UCC39421 PWM Controller. A schematic and parts list for the demonstration kit are included.
  • UCC39421 1-MHz 5-V Boost Evaluation Board (Rev. A)
    PDF, 40 Кб, Версия: A, Файл опубликован: 3 май 2000
    The UCC39421 Boost demo board implements a complete 1 MHz, 5 V Boost converter. The user needs only to supply an input voltage and a load.
Серия: UCC39421 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Controller (External Switch)
На английском языке: Datasheet Texas Instruments UCC39421PW
