Datasheet Texas Instruments TPS54310PWPG4 — Даташит
СерияTPS54310
МодельTPS54310PWPG4
Входное напряжение от 3 В до 6 В, синхронный понижающий преобразователь 3 А, 20-HTSSOP от -40 до 125
3-V to 6-V Input, 3-A Output Synchronous-Buck PWM Switcher With Integrated FETs (SWIFTв„ў) datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 19 дек 2014
IC REG BUCK ADJ 3A 20HTSSOP. Buck Switching Regulator IC Positive Adjustable 0.891V 1 Output 3A 20-PowerTSSOP (0.173', 4.40mm Width). PMIC...
TPS54310PWPG4
180 ₽
TPS54310PWPG4
1 641 ₽
МосЧип
TPS54310PWPG4
Hi-Tech Circuit Group
TPS54310PWPG4
Pin20
Package TypePWP
Industry STD TermHTSSOP
Package QTY70
МаркировкаTPS54310
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Control ModeVoltage Mode
Duty Cycle(Max)87 %
Iout(Max)3 A
Iq(Typ)6.2 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Power Good,Synchronous Rectification
Switching Frequency(Max)700 kHz
Switching Frequency(Min)280 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)3 В
Vout(Max)3.3 В
Vout(Min)0.9 В
  • Evaluation Modules & Boards: TPS54310EVM
    3-A, 3-6 Vin DC/DC Converter with Adjustable Output Down to 0.9V
  • Designing with the TPS54310 Synchronous Buck Regulator
    PDF, 130 Кб, Файл опубликован: 7 дек 2001
    The SWIFT TPS54310 externally compensated synchronous buck regulator makes designing a power solution quick and easy. The SWIFT Designer software tool is a resource that can greatly reduce design time by providing a complete power supply solution with only a few clicks of a mouse. The design methods presented in this application note are similar to the design methods used by the SWIFT Designe
  • Power for V5’s Transceiver using DC/DC Converters with Integrated FETs
    PDF, 89 Кб, Файл опубликован: 4 сен 2007
    This power supply was designed to power the transceivers in the Xilinxв„ў Virtexв„ў-5 LXT and FXT platforms.
  • Using 3.3-V Signals for Spartan-3 Configuration and JTAG Ports (Rev. A)
    PDF, 38 Кб, Версия: A, Файл опубликован: 13 апр 2004
  • Dual Output Power Supply Sequencing for High Performance Processors
    PDF, 6.0 Мб, Файл опубликован: 17 июл 2002
    Dual voltage power supply architectures are becoming commonplace in high performance microprocessor and digital signal processor (DSP) systems. To save power and increase processing speeds, processor cores have smaller geometry cells and require lower supply voltages than the system bus voltages. Power management in these systems requires special attention. Yesterday's power management ICs and app
  • Powering today’s multi-rail FPGAs and DSPs, Part 2
    PDF, 307 Кб, Файл опубликован: 18 апр 2006
Серия: TPS54310 (4)
На английском языке: Datasheet Texas Instruments TPS54310PWPG4
