Datasheet Texas Instruments TMX320VC5402PGE100 — Даташит
СерияTMS320VC5402
МодельTMX320VC5402PGE100
Процессор цифровых сигналов 144-LQFP от -40 до 100
TMS320VC5402 Fixed-Point Digital Signal Processor datasheet
PDF, 1.0 Мб, Версия: G, Файл опубликован: 20 окт 2008
TMX320VC5402PGE100*
TMX320VC5402PGE100
Pin144
Package TypePGE
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Width (мм)20
Length (мм)20
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ApplicationsCommunications and Telecom
Industrial
Approx. Price (US$)5.96 | 1ku
DSP1 C54x
DSP MHz (Max.)100
Operating SystemsDSP/BIOS
Operating Temperature Range(C)-40 to 100
RoHSНе совместим
  • Evaluation Modules & Boards: TMDSDSK5416
    TMS320C5416 DSP Starter Kit (DSK)
    XDS200 USB Debug Probe
  • Bootloading the TMS320VC5402 in HPI Mode
    PDF, 62 Кб, Файл опубликован: 29 апр 2002
    The TMS320VC5402 bootloader allows the system designer flexibility in memory configuration by providing many methods to boot the processor out of reset. One commonly used boot procedure allows a host microprocessor to load code into the TMS320VC5402 using the Host Port Interface (HPI) peripheral. This application report describes the HPI boot method and provides an example using the TMS320VC5402 D
  • TMS320VC5402 and TMS320UC5402 Bootloader (Rev. B)
    PDF, 301 Кб, Версия: B, Файл опубликован: 3 ноя 2004
    This document describes the features and operation of the TMS320UC5402 andTMS320VC5402 bootloader. The contents of the on-chip ROM are also discussed.Important Notice Regarding Bootloader Program Contents:Texas Instruments may periodically update the bootloader code supplied in the ROM to correct known problems, provide additional features, or improve functionality. These changes ma
  • Using the TMS320C5402 DSK Sine Program and evmdsk54x.dll
    PDF, 75 Кб, Файл опубликован: 11 ноя 2002
    The TMS320C5402 DSP starter kit (DSK) for Code Composer Studio? contains evmdsk54x.dll, a Windows library, and a header file, evmdsk54xdll.h, which allow you to use and write windows programs that can communicate with the TMS320C5402 DSK. An example program, sine, is included with Code Composer Studio, to demonstrate howevmdsk54x.dll can be used. The example contains a both WIN32 graphical us
  • Interfacing the TLV320AIC10/11 Codec to the TMS320C5402 DSP
    PDF, 580 Кб, Файл опубликован: 18 дек 2000
    This report describes how the analog interface circuit (AIC) device TLV320AIC10/11, 16-bit, 22-ksps audio codec has been applied in telephony (tone generation and echo cancellation) and speech (voice security system and voice-over IP). It describes the TMS320C54xx software architecture, and the hardware that has been developed and built. The C source code developed offers good reuse capabilities.
  • Interfacing the TLV320AIC12/13/14/15 Codec to the TMS320C5402? DSP
    PDF, 156 Кб, Файл опубликован: 24 окт 2002
    This application report presents the process of interfacing of the TLV320AIC12/13/14/15 voice-band codec with the TMS320C5402? DSP. It presents the hardware configuration and the software driver for a two-device cascade (single master and single slave) configuration mode. The design can be considered as an application example, a test tool, or a startup platform for developing and using the codec
  • Powering the TMS320VC5402 DSP Using the TPS60100, TPS76918, and the TPS3305-18
    PDF, 61 Кб, Файл опубликован: 16 дек 1999
    This report analyzes a low-cost, low-power supply design utilizing the TPS60100 dc-to-dc converter, the TPS76918 series regulator, and the TPS3305-18 power-supply supervisor to power DSP applications.
  • TPS6010x/TPS6011x Charge Pump (Rev. A)
    PDF, 391 Кб, Версия: A, Файл опубликован: 16 дек 1999
    Charge pumps are dc/dc converters that use a capacitor instead of an inductor or transformer for energy storage. They are able to generate positive or negative voltages from the input voltage. The input voltage can be multiplied by some factor such as 0.5, 2, 3, and so on, to generate the output voltage desired. Often, charge pumps and all related parts (including those used for energy storage) ar
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
На английском языке: Datasheet Texas Instruments TMX320VC5402PGE100
