Datasheet Texas Instruments TPS54290PWP — Даташит
Серия | TPS54290 |
Модель | TPS54290PWP |
Входное напряжение от 4,5 до 18 В, двойной синхронный понижающий преобразователь 1,5/2,5 А 16-HTSSOP от -40 до 145
TPS5429x 1.5-A and 2.5-A Dual, Fully-Synchronous Buck Converter With Integrated MOSFET datasheet
PDF, 1.9 Мб, Версия: A, Файл опубликован: 29 дек 2016
Pin | 16 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 90 |
Carrier | TUBE |
Маркировка | 54290 |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Control Mode | Current Mode |
Duty Cycle(Max) | 90 % |
Iout(Max) | 2.5 A |
Iq(Typ) | 1.8 мА |
Рабочий диапазон температур | от -40 до 145 C |
Package Group | HTSSOP |
Rating | Catalog |
Regulated Outputs | 2 |
Special Features | Enable,Phase Interleaving,Synchronous Rectification |
Switching Frequency(Max) | 300 kHz |
Switching Frequency(Min) | 300 kHz |
Тип | Converter |
Vin(Max) | 18 В |
Vin(Min) | 4.5 В |
Vout(Max) | 16.2 В |
Vout(Min) | 0.8 В |
- Evaluation Modules & Boards: TPS54291EVM-431
12V Input, 3.3V 1.5A and 1.2V and 2.5A Dual Sync Buck Converter Evaluation Module
- Understanding Thermal Dissipation and Design of a HeatsinkPDF, 59 Кб, Файл опубликован: 4 май 2011
Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: TPS54290 (2)
- TPS54290PWP TPS54290PWPR
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
