Datasheet Texas Instruments SN74LVC157ADRG3 — Даташит
СерияSN74LVC157A
МодельSN74LVC157ADRG3
Четверной 2-линейный селектор данных/мультиплексор 16-SOIC от -40 до 85
SN54LVC157A, SN74LVC157A datasheet
PDF, 1.1 Мб, Версия: Q, Файл опубликован: 1 янв 2011
Pin16
Package TypeD
Package QTY2500
МаркировкаLVC157A
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Полоса частот100 МГц
Bits2
Количество каналов4
Configuration2:1
Digital input leakage(Max)5 uA
ESD Charged Device Model0.75 kV
ESD HBM2 kV
F @ Nom Voltage(Max)100 Mhz
FunctionEncoder/Multiplexer
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)24/-24 мА
Schmitt TriggerNo
Technology FamilyLVC
ТипStandard
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)13.5,7.4,5.7,5 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
На английском языке: Datasheet Texas Instruments SN74LVC157ADRG3
