Datasheet Texas Instruments OPA603AU/1K — Даташит
СерияOPA603
МодельOPA603AU/1K
Высокоскоростной операционный усилитель с токовой обратной связью 16-SOIC
Datasheet
TSP
Pin16
Package TypeDW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA68XP
    DEM-OPA68xP: Demonstration Fixture
  • The Current-Feedback Op Amp: A High-Speed Building Block
    PDF, 117 Кб, Файл опубликован: 2 окт 2000
    Although current-feedback amplifiers (CFAs) have been in use for quite some time, there is a reluctance to view them in the same light as voltage-feedback amplifiers (VFAs). For instance, the gain-bandwidth curve of VFAs has a parallel in a transimpedance-bandwidth curve for CFAs. This parameter can be used to determine the closed-loop behavior of the CFA in same way that GBW can for the VFA. Not
  • Voltage-Feedback Amps vs Current-Feedback Amps: Bandwidth and Distortion
    PDF, 33 Кб, Файл опубликован: 27 сен 2000
    Current-feedback amplifiers have nearly constant bandwidth for varying closed-loop gains. The reason is that the user can adjust the open-loop gain of the current-feedback amplifier by changing the feedback network without affecting the open-loop pole.
  • Composite Op Amp Gives You The Best of Both Worlds
    PDF, 32 Кб, Файл опубликован: 27 сен 2000
    Classical op amps such as the OPA627 have excellent performance in applications where the required gain bandwidth is low compared to the gain-bandwidth product of the op amp. However, increasing closed-loop gain decreases the error-reducing loop gain. Furthermore, starting at relatively low frequencies, the loop gain rolls-off at 20dB/decade of signal frequency increase. In combination these effec
Серия: OPA603 (3)
На английском языке: Datasheet Texas Instruments OPA603AU/1K
