Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74AS04DRG4 — Даташит
СерияSN74AS04
МодельSN74AS04DRG4
Шестигранные инверторы 14-SOIC от 0 до 70
Hex Inverters datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 1 дек 1994
Pin14
Package TypeD
Package QTY2500
МаркировкаAS04
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Bits6
F @ Nom Voltage(Max)125 Mhz
ICC @ Nom Voltage(Max)0.0042 мА
Output Drive (IOL/IOH)(Max)-2/20 мА
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)11 нс
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74AS04DRG4
