Datasheet Texas Instruments SN74HC244PWRG4 — Даташит
| Серия | SN74HC244 |
| Модель | SN74HC244PWRG4 |
Восьмеричные буферы и линейные драйверы с выходами с 3 состояниями 20-TSSOP от -40 до 85
SNx4HC244 Octal Buffers and Line Drivers With   3-State Outputs datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 24 май 2016
 Купить SN74HC244PWRG4 на РадиоЛоцман.Цены — от 11 до 29 ₽14 предложений от 11 поставщиков IC BUFFER NON-INVERT 6V 20TSSOP. Buffer, Non-Inverting 2 Element 4 Bit per Element 3-State Output 20-TSSOP. Logic - Buffers, Drivers, Receivers,...  | |||
| SN74HC244PWRG4 Texas Instruments  | 11 ₽ | ||
| SN74HC244PWRG4 Texas Instruments  | 13 ₽ | ||
| SN74HC244PWRG4 Texas Instruments  | 29 ₽ | ||
| SN74HC244PWRG4 Texas Instruments  | по запросу | ||
| Pin | 20 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | HC244 |
| Width (мм) | 4.4 |
| Length (мм) | 6.5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 28 Mhz |
| ICC @ Nom Voltage(Max) | 0.08 мА |
| Output Drive (IOL/IOH)(Max) | -7.8/7.8 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | HC |
| VCC(Max) | 6 В |
| VCC(Min) | 2 В |
| Voltage(Nom) | 6 В |
| tpd @ Nom Voltage(Max) | 29 нс |
- Simultaneous-Switching Performance of TI Logic Devices (Rev. B)PDF, 378 Кб, Версия: B, Файл опубликован: 23 фев 2005
Simultaneous-switching noise can generate and propagate glitches in electronic systems. Therefore, system designers are faced with challenges to minimize simultaneous-switching noise, while increasing switching speed and improving signal quality. This report presents the performance of different TI logic devices under various simultaneous-switching conditions. Factors such as the number of bits sw
Серия: SN74HC244 (25)
- SN74HC244ADBLE SN74HC244APWLE SN74HC244DBLE SN74HC244DBR SN74HC244DBRG4 SN74HC244DW SN74HC244DWE4 SN74HC244DWG4 SN74HC244DWR SN74HC244DWRE4 SN74HC244DWRG4 SN74HC244N SN74HC244N3 SN74HC244NE4 SN74HC244NSR SN74HC244NSRG4 SN74HC244PW SN74HC244PWE4 SN74HC244PWG4 SN74HC244PWLE SN74HC244PWR SN74HC244PWRE4 SN74HC244PWRG4 SN74HC244PWT SN74HC244QDWRG4Q1
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
