Datasheet Texas Instruments LM741H — Даташит
СерияLM741-MIL
МодельLM741H
Операционный усилитель 8-ТО-99 от -55 до 125
LM741-MIL Operational Amplifier datasheet
PDF, 741 Кб, Файл опубликован: 13 июн 2017
Pin88
Package TypeLMCLMC
Industry STD TermTO-CANTO-CAN
JEDEC CodeO-MBCY-WO-MBCY-W
Package QTY500500
МаркировкаLM741HLM741H
Width (мм)9.089.08
Length (мм)9.089.08
Thickness (мм)4.44.4
Pitch (мм)2.542.54
Max Height (мм)5.725.72
RoHSSee ti.com
  • AN-711 LM78S40 Switching Voltage Regulator Applications (Rev. B)
    PDF, 740 Кб, Версия: B, Файл опубликован: 7 май 2013
    This application note describes a new integrated subsystem that contains the control circuitry, as well asthe switching elements, required for constructing switching regulator systems.
  • AN-71 Micropower Circuits Using the LM4250 Programmable Op Amp (Rev. B)
    PDF, 536 Кб, Версия: B, Файл опубликован: 1 май 2013
    This application report describes the circuit operation of the Texas Instruments LM4250, various methodsof biasing the device, frequency response considerations, and some circuit applications exercising theunique characteristics of the LM4250.
  • LM118 Op Amp Slews 70 V/sec
    PDF, 118 Кб, Файл опубликован: 1 окт 2002
    LM118 Op Amp Slews 70 V/ГѓВґsec
  • Low Drift Amplifiers
    PDF, 71 Кб, Файл опубликован: 2 окт 2002
  • Predicting Op Amp Slew Rate Limited Response
    PDF, 139 Кб, Файл опубликован: 7 окт 2002
  • LM143 Monolithic High Voltage Operational Amplifier Applications
    PDF, 479 Кб, Файл опубликован: 2 май 2004
    Application Note 127 LM143 Monolithic High Voltage Operational Amplifier Applications
  • AN-79 IC Preamplifier Challenges Choppers on Drift (Rev. B)
    PDF, 940 Кб, Версия: B, Файл опубликован: 1 май 2013
    Since the introduction of monolithic IC amplifiers there has been a continual improvement in DC accuracy.Bias currents have been decreased by 5 orders of magnitude over the past 5 years. Low offset voltagedrift is also necessary in a high accuracy circuits. This is evidenced by the popularity of low drift amplifiertypes as well as the requests for selected low-drift op amps. However until n
  • AN-480 A 40 MHz Programmable Video Op Amp
    PDF, 218 Кб, Файл опубликован: 11 май 2004
  • Get Fast Stable Response From Improved Unity-Gain Followers
    PDF, 107 Кб, Файл опубликован: 2 окт 2002
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
На английском языке: Datasheet Texas Instruments LM741H
