Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74AVCH8T245PWR — Даташит
СерияSN74AVCH8T245
МодельSN74AVCH8T245PWR
8-битный приемопередатчик с двойной шиной питания, настраиваемым преобразованием напряжения и выходами с 3 состояниями 24-TSSOP от -40 до 85
SN74AVCH8T245 8-Bit Dual-Supply Bus Transceiver With Configurable Level-Shifting, Voltage Translation, and 3-State Outputs datasheet
PDF, 1.1 Мб, Версия: H, Файл опубликован: 1 апр 2016
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаWP245
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Bits8
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.016 мА
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyAVC
VCC(Max)3.6 В
VCC(Min)1.2 В
Voltage(Nom)1.2,1.5,1.8,2.5,3.3 В
tpd @ Nom Voltage(Max)2.7,2.5,2.4,2.3 нс
  • Evaluation Modules & Boards: AVCLVCDIRCNTRL-EVM
    Generic EVM for Direction-Controlled Bidirectional Translation Device Supporting AVC and LVC
  • Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
    Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i
  • AVC Logic Family Technology and Applications (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
    Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control (
  • Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)
    PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Semiconductors > Logic > Voltage Level Translation > Direction Controlled Voltage Translation
На английском языке: Datasheet Texas Instruments SN74AVCH8T245PWR
