Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74CB3Q3306APWG4 — Даташит
СерияSN74CB3Q3306A
МодельSN74CB3Q3306APWG4
Двойной полевой транзистор 2,5 В/3,3 В, низковольтный, широкополосный коммутатор шины 8-TSSOP от -40 до 85
SN74CB3Q3306A datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 25 янв 2011
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesIOFF
Approx. Price (US$)0.29 | 1ku
Bandwidth(MHz)500
ConfigurationSPST
Crosstalk(dB)No
ESD Charged Device Model(kV)1
ESD HBM(kV)2
ICC(Max)(uA)700
Input/Ouput Voltage(Max)(V)5.5
Input/Output Continuous Current(Max)(mA)64
Number of Channels(#)2
Operating Temperature Range(C)-40 to 85
Package GroupTSSOP
Package Size: mm2:W x L (PKG)8TSSOP: 19 mm2: 6.4 x 3(TSSOP)
Ron(Max)(Ohms)9
Ron(Typ)(Ohms)5
VCC(Max)(V)3.6
VCC(Min)(V)2.3
RoHSНе совместим
  • Evaluation Modules & Boards: DLPLCR9000EVM
    DLPВ® LightCrafterв„ў 9000 Evaluation Module
  • Evaluation Modules & Boards: TMDXEVM388
    DM388 DaVinci Digital Media Processor Evaluation Module
  • Evaluation Modules & Boards: DIP-ADAPTER-EVM
    DIP Adapter Evaluation Module
  • CBT-C, CB3T, and CB3Q Signal-Switch Families
    PDF, 584 Кб, Файл опубликован: 4 фев 2003
    Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot
На английском языке: Datasheet Texas Instruments SN74CB3Q3306APWG4
