Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS5410DG4 — Даташит
СерияTPS5410
МодельTPS5410DG4
Входное напряжение от 5,5 В до 36 В, 1 А, 500 кГц Понижающий преобразователь 8-SOIC от -40 до 125
TPS5410 1-A, Wide Input Range, Step-Down Converter datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 12 дек 2014
Package TypeD
Package QTY75
МаркировкаTPS5410
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Control ModeVoltage Mode
Duty Cycle(Max)87.5 %
Iout(Max)1 A
Iq(Typ)3 мА
Regulated Outputs1
Special FeaturesEnable
Switching Frequency(Max)500 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)36 В
Vin(Min)5.5 В
Vout(Max)31 В
Vout(Min)1.23 В
  • Evaluation Modules & Boards: TPS5410EVM-203
    1-A Converter Evaluation Module
  • Using the TPS5430 As An Inverting Buck Boost Converter (Rev. A)
    PDF, 266 Кб, Версия: A, Файл опубликован: 15 авг 2007
    The wide input voltage range SWIFTв„ў dc/dc converters are used typically as step-down converters where the derived output is a positive voltage less than the input voltage source. In some cases, it may be required to generate a negative voltage from the input voltage source. In such instances, it is possible to configure the TPS5430/20/10 devices in an inverting buck-boost topology, where the outpu
  • Using TPS5410/20/30/31/50 w/Aluminum/Ceramic Output Capacitors (Rev. C)
    PDF, 392 Кб, Версия: C, Файл опубликован: 21 мар 2007
    As internally compensated devices, the wide input step-down SWIFTв„ў DC/DC converters, including TPS5410/5420/5430/5431/5450, have the advantages of less external part count and reduced design complexity, as well as limited output capacitor selection. By adding only two or three external components into the standard circuitry, these devices generally work well with aluminum/ceramic output capacitors
Серия: TPS5410 (5)
На английском языке: Datasheet Texas Instruments TPS5410DG4
