Datasheet Texas Instruments THS6053IPWP — Даташит
СерияTHS6053
МодельTHS6053IPWP
Драйвер линии ADSL CPE, 175 мА, +/-12 В с отключением 14-HTSSOP от -40 до 85
175 mA +/-12 V ADSL CPE Line Drivers datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 13 дек 2001
Pin14
Package TypePWP
Industry STD TermHTSSOP
Package QTY90
МаркировкаHS6053I
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураCurrent FB
BW @ Acl170 МГц
CMRR(Min)59 дБ
CMRR(Typ)66 дБ
GBW(Typ)170 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)7 мА
Iq per channel(Typ)5.2 мА
Количество каналов2
Offset Drift(Typ)30 uV/C
Output Current(Typ)175 мА
Package GroupHTSSOP
Package Size: mm2:W x L14HTSSOP: 32 mm2: 6.4 x 5(HTSSOP) PKG
Rail-to-RailNo
Slew Rate(Typ)1700 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at Flatband(Typ)2.1 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)10 мВ
  • Evaluation Modules & Boards: THS6053EVM
    THS6053 Evaluation Module
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
Серия: THS6053 (4)
На английском языке: Datasheet Texas Instruments THS6053IPWP
