Datasheet Texas Instruments TMS320DM355CZCEA13 — Даташит
СерияTMS320DM355
МодельTMS320DM355CZCEA13
Цифровая медиасистема на кристалле (DMSoC) 337-NFBGA
TMS320DM355 Digital Media System-on-Chip (DMSoC) datasheet
PDF, 1.2 Мб, Версия: G, Файл опубликован: 24 июн 2010
Pin337337337337
Package TypeZCEZCEZCEZCE
Industry STD TermNFBGANFBGANFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-NS-PBGA-N
МаркировкаDM355ZCEA135TMS320DM355CZCE A135
Width (мм)13131313
Length (мм)13131313
Thickness (мм).89.89.89.89
Pitch (мм).65.65.65.65
Max Height (мм)1.31.31.31.3
ARM CPU1 ARM9
ARM MHz (Max.)135
216
270
ApplicationsConsumer Electronics
Energy
Industrial
Medical
SecurityVideo and Imaging
Approx. Price (US$)15.91 | 1ku
DRAMLPDDR
DDR2
I2C1
Operating SystemsNeutrino
PrOS
Integrity
Windows Embedded CE
Linux
Operating Temperature Range(C)-40 to 100
Pin/Package337NFBGA
SPI3
UART(SCI)3
USB1
Video Acceleration1 MJCP
Video Port (Configurable)1 Dedicated Input
1 Dedicated Output
Video Resolution/Frame RateD1 or Less
720p
RoHSНе совместим
  • Development Kits: TMDSEVM355
    TMS320DM355 Digital Video Evaluation Module
    Статус продукта: NRND (Не рекомендуется для новых разработок)
    XDS200 USB Debug Probe
  • Implementing DDR2/mDDR PCB Layout on the TMS320DM35x DMSoC (Rev. D)
    PDF, 127 Кб, Версия: D, Файл опубликован: 11 ноя 2009
    the TMS320DM35x Digital Media System-on-Chip (DMSoC) device. The approach to specifying interface timing for the DDR2/mDDR interface is quite different than on previous devices.The previous approach specified device timing in terms of data sheet specifications and simulation models. The system designer was required to obtain compatible memory devices, as well as the device-specific data sheet
  • TMS320DM355 Power Consumption for Common Application Usage Scenarios (Rev. A)
    PDF, 53 Кб, Версия: A, Файл опубликован: 16 июл 2010
    This document discusses the power consumption for common system application usage scenarios for the TMS320DM355 digital media system-on-chip (DMSoC) processor. Power consumption is highly dependent on the individual user's application; however, this document focuses on providing several DM355 application-usage case scenarios and the environment settings that were used to perform such power measure
  • TMS320DM355/335 Migration Guide (Silicon revision 1.1, 1.3 and 1.4) (Rev. B)
    PDF, 75 Кб, Версия: B, Файл опубликован: 5 янв 2011
    This application report describes the differences between Silicon revision 1.1, 1.3 and 1.4 of the TMS320DM355/DM335 digital media system-on-chip (DMSoC). This document discusses behavior different from that described in the TMS320DM355 Digital Media System-on-Chip (DMSoC) ARM Subsystem User's Guide (SPRUFB3) and the TMS320DM335 Digital Med
  • Migrating From TMS320DM35x to TMS320DM36x Devices (Rev. A)
    PDF, 79 Кб, Версия: A, Файл опубликован: 2 июн 2011
    For purposes of comparison, this application report describes the key features of the TMS320DM36x (DM36x) and the TMS320DM35x (DM35x) digital media processors.
  • Powering the TMS320DM335 and TMS320DM355 with the TPS650061
    PDF, 144 Кб, Файл опубликован: 13 окт 2011
    TPS650061, TMS320DM335, TMS320DM355 Powering the DM335 and DM355 with the TPS650061
  • TMS320DM355 DSP Power Reference Design PR742 (Rev. A)
    PDF, 199 Кб, Версия: A, Файл опубликован: 8 авг 2008
    This reference design is for the TMS320DM335/DM355 digital signal processor (DSP) and accounts for voltage, current, and sequencing requirements. The operating input voltage ranges from 2 V to 5.5 V for Li-ion batteries and 3 AA batteries. This design also can work with 2 AA batteries with some limitations. The design is optimized for efficiency over the full range of operation and low overall cos
  • USB Compliance Checklist (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 10 мар 2010
  • LSP 2.10 DaVinci Linux Drivers (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 8 июл 2009
  • Building a Small Embedded Linux Kernel Example (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 27 май 2008
    Building a Small Embedded Linux Kernel Example Application Report
  • EDMA v2.0 to EDMA v3.0 (EDMA3) Migration Guide (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 21 авг 2008
    This application report summarizes the key differences between the enhanced direct memory access (EDMA3) used on C64x+в„ў DSP devices and the EDMA2 used on TMS320C64xв„ў DSP devices, and provides guidance for migrating from EDMA2 to EDMA3.
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > DaVinci Video Processors
На английском языке: Datasheet Texas Instruments TMS320DM355CZCEA13
